Turns on or off link-flap detection.
| ports | Physical ports. |
| port_list | List of ports to activate link-flap detection upon. |
| all | Activates link-flap detection on all port in the system. |
| on | Link-flap detection is on. |
| off | Link-flap detection is off. |
Link-flap detection is disabled by default.
The following example turns off link-flap detection on ports 1–15:
Configure ports 1-15 link-flap-detection off
This command was first available in ExtremeXOS 22.1.
